G.P. flywheel seal
34gpa
09-15-2004 11:36:18
The gp I just bought is throwing some oil out the flywheel side. Is there a cork seal there that goes on like the A"s,B"s etc? If so do you know the part no? Thanks for the help
paul o
09-15-2004 19:01:44
 Re: G.P. flywheel seal in reply to 34gpa, 09-15-2004 11:36:18
Chooch is correct. Some people use an O ring, I use a Chicago Rawhide lip seal on the inside of the oil slinger
ET
09-15-2004 17:35:00
You could try a light lair of high temp silicone on the crank where the slinger sets. The crank shaft endplay needs to be set at .005 to .010.
Chooch
09-15-2004 14:23:17
34gpa,
I do not believe that GP's have a flywheel seal, at least the small bores do not. However, with a little help from a machine shop, a groove can be cut in the back of the oil slinger so that one can be installed similiar to that on a D or AR.
