John Deere 2 bottom hyd plow on rubber.
John Humphrey M
09-16-2004 08:59:00
I just aquired a JD 2 bottom, on rubber. 16" between the points, 10 spoke 16" wheels, formed steel wheel which is rasied when the hyd picks the plow up at the end of the row. What more do I need to describe to ID this so that I can buy parts?
john in ohio
09-16-2004 16:15:52
 Re: John Deere 2 bottom hyd plow on rubber. in reply to John Humphrey Morocco IN., 09-16-2004 08:59:00
sounds like you have a 44H.
edchainsaw
09-16-2004 20:12:09
 Re: John Deere 2 bottom hyd plow on rubber. in reply to john in ohio, 09-16-2004 16:15:52
Yes about has to be a 44H but I am wandering if its set for 16's.. it could be but most were set at 14. ( I learned at an expo that 44's could be set 12,14,16 from the way the arm shifts as it goes down from the frame to the moldboard and point)
Larry806
09-17-2004 07:26:29
 Re: John Deere 2 bottom hyd plow on rubber. in reply to edchainsaw, 09-16-2004 20:12:09
I have a 44 that can be 10's or 12's how rare would that be? Larry
edchainsaw
09-18-2004 20:59:30
 Re: John Deere 2 bottom hyd plow on rubber. in reply to Larry806, 09-17-2004 07:26:29
I think it would be really rare... I was unaware that Deere made any that were 10's
