later pistons in A
34gpa
09-17-2004 08:14:06
I need to bore my unstyled A block out and Im not finding 45 over pistons, but a friend has some out of a 44 A. Will they fit if I also use the later rods with them?
swede
09-17-2004 12:01:44
 Re: later pistons in A in reply to 34gpa, 09-17-2004 08:14:06
You can use your original rods if you have the wrist pin bushings honed to fit the larger pins on the later pistons.
nigelB
09-17-2004 09:00:50
will fit only real differance between the two are the rings,will also take the rods the later ones are just more rugged!
