TURN UP THE HORSEPOWER ON 4010?
4010
09-17-2004 13:16:09
I am going to a local tractor pull, and was wondering if there is a quick, easy way to give to 4010 diesel a few more horses? Is there a way to turn up the fuel, and how?
Chip
09-18-2004 21:08:54
 Re: TURN UP THE HORSEPOWER ON 4010? in reply to 4010, 09-17-2004 13:16:09
Dump the oil out of the air filter and run it dry (Needs more air for more horsepower) Check Injection pump timing (advance it 4 degrees) check throttle linkage making sure you get full throttle,Turn up RPM a LITTLE, Check valve rocker arm lash. Take fan blade off (robs HP) take muffler off. Have to take the pump off to get it turned up. Go Get em!
