70 question
troubles
09-18-2004 16:49:29
I was wondering if there is a trick to instaling the lower water pipe on a 70 diesel , I put in new o-rings on both ends but it still leaks I just used soap to push the pipe in. any tips would be appreciated. thanks
JDG
09-18-2004 21:56:43
 Re: 70 question in reply to troubles, 09-18-2004 16:49:29
Had same trouble with a "G".I took water pump off and housing off head. Assemble off tractor pushing pipe together far enough to get water pump and housing to head gaskets in. No leaks!!!
PeteNY
09-18-2004 20:12:34
One of the most frustrating and repeated steps in our rebuild...finally bought 6 o rings, used dish soap and the 4th one(5th try 'cause I only had one the 1st time) didn't get cut...great tractor though! Pete
Jimmy
09-18-2004 18:44:19
 John Deere 1947 M in reply to troubles, 09-18-2004 16:49:29
Seeking information on transmission and rear axle noise for a John Deere Model M 1947.
F-I-T
09-18-2004 17:22:36
Troubles:
Assuming that your pipe is straight and smooth and without defects (at my age I can only hope that is the case) I'd guess that you cut or rolled one of the o-rings.
I did a front to back rebuild project on my 70 Diesel a year or so ago, and after all the work I performed, getting those o-rings in was one of the most difficult jobs I had to do. Whenever I do one, I have 3 or 4 extra o-rings on hand to save myself a trip to town.
Now for the tip....
09-18-2004 17:26:54
 Re: 70 question in reply to F-I-T, 09-18-2004 17:22:36
I cut 4, 1/2" wide strips out of a lacquer thinner can, filed off the burrs, and laid those in the throat of the casting so the o-ring was trapped in the groove. Then I slid the well lubricated pipe into place. Then I pulled the strips back out and had no leaks on either pipe, upper or lower. The strips keep the o-ring from rolling out of the groove as you push in the pipe.
Frank
Mike M
09-18-2004 18:18:17
 Re: 70 question in reply to Now for the tip...., 09-18-2004 17:26:54
Here's a better tip for you. I use RTV gasket maker smear all over the o-rings before installation then put a little on the pipe to fill in the pits. That silicone RTV really helps them slide into place then when dry fills in the pits and seals.
troubles
09-20-2004 07:05:27
 Re: 70 question in reply to Mike M, 09-18-2004 18:18:17
thanks for all the tips on the water pipe , it sounds like im not the only one that has had a little problem with the leaking. this site is great for answering any question that comes up
