AXLE DIMENSIONS OF 4010 4020 THE SAME???
4010 Owner
09-19-2004 09:10:40
I have a set of 9 Bolt hubs off a 4020, I put them on my 4010 and there is lots of play. Is the axle size different between the 4010 and 4020???
Gerald J.
09-19-2004 16:47:13
 Re: AXLE DIMENSIONS OF 4010 4020 THE SAME??? in reply to 4010 Owner, 09-19-2004 09:10:40
4020 axle is definitely bigger than 4010.
I'm looking for just that set of hubs for my 4020 for duals. Where are you and what would you want?
Gerald J.
4010 Owner
09-20-2004 14:19:00
 Re: AXLE DIMENSIONS OF 4010 4020 THE SAME??? in reply to Gerald J., 09-19-2004 16:47:13
I will probably be interested in selling them and purchasing the correct size for a 4010, or would trade for the correct ones even up. Not sure right off hand what I would ask for them. Give me your E-mail address so I can get back to you. I'm located in Central Michigan.
Gerald J.
09-23-2004 17:54:33
 Re: AXLE DIMENSIONS OF 4010 4020 THE SAME??? in reply to 4010 Owner, 09-20-2004 14:19:00
third party image
Let me try showing my hidden e-mail address as a graphic.
Gerald J.
Gerald J.
09-20-2004 20:56:07
My email address shows up on some of my web pages.
Gerald J.
I Bleed Green
09-19-2004 16:32:15
4010 axle diameter 3 1/8 inches. 4020 3 3/8 inches.
F-I-T
09-19-2004 09:29:34
4010:
I don't have the dimensions, but yes they are different. From reading on this board, I believe the 4010 and the 4000 shared common sizes, but not sure they the same axles.
Frank
Bob
09-19-2004 09:27:45
This was covered a couple of months back, and I BELIEVE the information given was correct.
Anyhow, the 4010's are definitely smaller.
