JD 50 Hydraulics
JeffZ
10-08-2004 11:30:52
I removed this valve from a John Deere 50.
third party image
It had an aftermarket 3 point and a loader. With this valve you could run the loader and have an extra cylinder outlet plus not disturb the use of the rockshaft operated 3 point. Altho I did take it off another tractor awhile back I am now trying to put it on my 50 and am not quite sure how it goes. I believe the end with the hose went in up by the distributor and the other end (you can see the male fitting end in the upper right) went down behind below the rockshaft. Has anybody had any experience with these and know what I need to do? Also any good ideas as far as tapping into the lines?
ET
10-08-2004 11:40:07
 Re: JD 50 Hydraulics in reply to JeffZ, 10-08-2004 11:30:52
This would have to be an open center valve and it would be plumbed into the pressure line from the pump. The return side of this valve would be hooked to the powertrol where the pressure line feeds it. The pressure oil flows through the valve to the powertrol. Hope this helps.
