Or you could turn her down a little bit!
'51 A
10-16-2004 00:36:30
You must have your old fine unit cranked too the max for that tractor to burn the decal off the hood. I had one cranking 180 and had no problem with the hood paint being burned off.
okiedirtfarmer
10-16-2004 05:19:31
 Re: Or you could turn her down a little bit! in reply to '51 A, 10-16-2004 00:36:30
Its only set at the top ond of the specs. I put a new injection pump on just over a year ago and had it set at the top of John deere specs. I don't use it near as much for primary tillage work anymore so I didn't see the need in cranking it up.
