JD M Hydraulics Problem
1947 M
10-17-2004 18:28:31
I have an early model John Deere M which is having problem's with the hydraulics. On a cold start up I have great pressure but as the tractor warms up I start losing pressure. After the tractor warms up the pressure will slowley build to about 550 - 600psi. I am using 10 wt. non detergent oil. I have the pressure relief valve set to one turn off from the seat. Any suggestion's? Dose anyone make a rebuild kit for the John Deere Touch O Matic?
