Charging system on a 4010 Diesel.
4010
10-24-2004 19:45:18
Will the alternater still charge the battery when the tractor is running and the key is turned off?
gusc
10-25-2004 23:17:03
 Re: Charging system on a 4010 Diesel. in reply to 4010, 10-24-2004 19:45:18
2pop is right, the alternator will continue to charge with the switch off. It self excites back through terminal #1. I have a switch on terminal #2 on my 60 to turn off the alt. If I don't it feeds back to the ignition and the tractor engine won't shut off.
All you have to doto find out for sure is put a voltmeter on the battery terminals. If the voltmeter reads about a volt more than battery voltage the alt is still charging.
txblu
10-25-2004 09:12:26
Wanna get in here somewhere, don"t know where.
Mine is OEM 24v system with 24v gen and regl. 2 batteries, 1 +, 1 - to chassis.
As Roy said, on mine, if you don"t excite it, it doesn"t produce. Excitement has to come through the ign switch as otherwise it would run the batteries down when engine is off.
Starter may be 12v (still OEM) cause with the batteries mounted right next to the starter (homemade batt box), (950CCA) and 00 gauge wiring less than 15" each, the sucker screams to life when you tell it to.
Mark
Jason Z in MO
10-25-2004 09:28:44
 Re: Charging system on a 4010 Diesel. in reply to txblu, 10-25-2004 09:12:26
Are you saying your starter is 12volt?
If so, then either 2 things I can think of are happening. 1) the starter is actually 24v and in good shape. 2) the right hand battery does nothing, at least it isn"t used during cranking.
I am assuming you have a pair of 12 volt batteries. I am curious what brand you have with 950 CCA? I just bought a pair of JD strong box"s for my 4020 and they are 650 CCA at 0 deg F.
Sounds like some strong batteries!
txblu
10-25-2004 09:39:35
 Re: Charging system on a 4010 Diesel. in reply to Jason Z in MO, 10-25-2004 09:28:44
Boy that was quick.
Batteries. Got them from an OTR (18 wheeler) dealership. Has a size 31 which is the size of a (boat"s trolling motor 27 size) but like a trolling batt, has studs instead of the lead posts. Also unlike the troll batt, it delivers lots of current on demand. Would bet that the starter sucks 300 amps when you smack it.
I am basing my assumption of the 12v starter on the fact that it spins so fast when I hit it. I know Ford used 6v starters on 12v systems for years. Maybe Deere did the same. If it"s important, I can scratch the paint off the nameplate and see if it defines the voltage. Since you are only on the starter for a short period, and there is a lot of mass (weight to get hot) it is not unrealistic to have a 12 v on a 24 system.
Besides, some tractors are parallel batteried 12v systems and they would have to build 2 different starters for that and (personal opinion) I doubt that.
My batteries are stacked in series with tractor ground being in the center (one + system, one - system) The gen goes across both with the 24 volts.
Mark
Jason Z in MO
10-25-2004 09:55:16
 Re: Charging system on a 4010 Diesel. in reply to txblu, 10-25-2004 09:39:35
Yeah, this stuff is fast!
Thanks for the response! I thought about checking the parts web site to see if the 4020 gas and 4020 Diesel used the same starter part number. I dismissed that because even if they share the same guts doesn"t mean JD would give them the same part number. Other stuff might be different.
txblu Jason heads up
10-25-2004 09:45:31
I lied. I was brousing farther thru the posts where they were talking about a cross over cable and all and I remembered.
Rather than one batt wire going the starting solenoid (most starters) this starter has a second terminal on the side which is for the other battery.
It is a 24 volt starter. So a 12v conversion would have to address gen, vr, and starter. To say that you could do it with the same starter, I'd have to look at the schematic of the starter.
Sorry for the confusion.
Mark
Jason Z in MO
10-25-2004 10:09:44
 Re: Charging system on a 4010 Diesel. in reply to txblu Jason heads up, 10-25-2004 09:45:31
I should have been more specific with this statement:
"The 12 volt starter would have to be isolated from ground to spin it with 24 volts."
This is true with these tractors that use the chassis to connect or string the two batteries together. So from chassis to any battery post is either 0 volts or 12 volts.
txblu
10-25-2004 10:23:58
 Re: Charging system on a 4010 Diesel. in reply to Jason Z in MO, 10-25-2004 10:09:44
In this case, after contemplating, no, the starter is not isolated; but there is an isolated winding within the starter. Hence the second terminal on the starter case.
Since the batteries are in series, they both have to be connected to work. Hence one switch (starting solenoid mounted on top) can suffice to operate the 2 batteries and one starter. Since the start/gen/reg loop is on 24 volts, it cares less about tractor chassis. Only the acc and lights are really hooked to that.... and it (the chassis) serves as the "link cable" mentioned in other similar posts back a couple of days.
One more thing. I broke my solenoid hooking up this "cable" (00 size wiring) and bought a replacement from Walts, via this web "tractor parts" inquiry. Seemed very knowledgeable. Maybe he can answer any questions you may have about what part number starter goes to what tractor.
Enjoyed yakin.
Mark
Jason Z in MO
10-25-2004 10:02:08
Yep, I am about to hang new batteries and install new cables on my 4020 project. I was just looking over the service manual this weekend. Which said the crossover cable was added after SN 91000. Not that it matters electrically other than during high current loads.
twopop
10-25-2004 06:45:11
I disagree with roy.if you are using a s10 type delco alternator,it will charge,once it has been excited,until it quits turning.the alternator set up is used on a 30 series deeres,when the key is turned off,the a/c blowers and the radio will continue to work until the motor stops.
buickanddeere
10-25-2004 06:44:20
Alternator on a 4010? It would have to be a conversion to have an alternator on a 4010. It may or may not charge depending on the wiring method and alternator internals.
Roy Suomi
10-24-2004 19:55:17
Nope. You have to power the stator and field terminal.. via key switch
