How do you crank up regulator
Jim Nauert
10-27-2004 18:08:27
How do you crank a voltage regulator to let it put out more voltage this would be on my 420 12volt
Bob
10-28-2004 10:53:50
 Re: How do you crank up regulator in reply to Jim Nauert, 10-27-2004 18:08:27
Put as simply as possible, if your system is working, but just needs the voltage regulator set-point raised:
1.) Disconnect the battery, for safety.
2.) Carefully remove the cover from the voltage regulator.
3.) Locate the voltage regulator unit. It will be the coil wound with the lightest gauge wire.
4.) VERY SLIGHTLY increase the spring tension on the armature (hinged lever that has points on one end) of that coil. Older units had an adjusting screw for this, newer units require bending of the stationary "hook" the sprig attaches to.
After making a TINY increase in the spring tension, put the cover back on the regulator, re-connect the battery, start the engine, and after a warm-up and charging period, chaeck the battery voltage again.
Repeat the whole process, if necessary.
Just BE CAREFULL, and only adjust a TINY bit at a time.
buickanddeere
10-28-2004 08:04:04
Spend a few bucks for a new 12V regulator, the old one maybe getting tired by now anyways. You cannot tweek a 6V regulator to double it's factory design control band. For an odd jobs tractor or cool weather operation. Set the regulator to 14.2V measured at the battery at fast idle speed. 13.8V for hot weather or long duration usage.
Jim Nauert
10-28-2004 09:17:28
 Re: How do you crank up regulator in reply to buickanddeere, 10-28-2004 08:04:04
Reg. is brand new just put it on two months ago. Ran it at a higher rpm seems to work ok might have to go with a smaller pully. Thanks
Roy Suomi
10-27-2004 20:09:57
You can clean contacts on spring loaded levers on top of copper coils. If that doesn't work, run a piece of emery cloth on the generator armature commutator. [ where the brushes run ] while running. Try not to short out brushes with a screw driver.
