Power Steering - 520
Jim Dunn
11-04-2004 05:33:10
I am in the finishing stages of restoring my 520 and when I start it, it turns the wheels to the left. Does anyone know how I can bleed some air out of the system or do whatever it will take to correct this problem?
WTW
11-04-2004 10:34:00
 Re: Power Steering - 520 in reply to Jim Dunn, 11-04-2004 05:33:10
I think CLW met to say, back out the four 3/8" bolts holding steering valve housing to the steering worm housing and adjust forward or rearward to center steering valve to worm actuator as he correctly described. The worm housing is held to steering post with four 1/2" bolts and there is no need to disturb these to make the adjustment CLW described. Good Luck, DW
CLW
11-04-2004 06:03:06
Jim, raise the front wheels just off the ground. Back the four bolts holding the worm gear housing off just enough that you can move it back or forward with light taps of a hammer. With the engine running tap it back and the wheels will move one way, forward the other. Move it until the wheels are centered and stay there. Thighten bolts. Job done.
CLW
Jim Dunn
11-04-2004 10:31:15
 Re: Power Steering - 520 in reply to CLW, 11-04-2004 06:03:06
Just want to thank CLW for the good advise and quick response. It was a 10 minute job, once I knew where to start. If we ever meet, I'll buy the ice cream cones.
Thanks again,
Jim
CLW
11-04-2004 12:42:21
 Re: Power Steering - 520 in reply to Jim Dunn, 11-04-2004 10:31:15
Jim, I like chocolate. WTW you are correct, I looked at the wrong line of my parts book. Thanks.
CLW
Jim Dunn
11-04-2004 17:27:28
 Re: Power Steering - 520 in reply to CLW, 11-04-2004 12:42:21
This time I'll thank both of you guys. After having the steering gear apart earlier this summer to take out some shims that allowed me to tighten the bearing clearances and seeing the internals, I just needed the info that CLW provided. The housing with the 4 half inch bolts is also doweled, so it didn't take much concentration to figure out what was adjustable and what wasn't.
Thanks again,
Jim
