LIVE PTO Conversion
18615824
11-04-2004 20:08:34
I have an opportunity to buy a junked-out JD 50 with a live PTO. I was thinking of buying it in order to put the live PTO on my tractor.
Has anyone ever tried that? Can it be done within a reasonable amount of man hours?
Thanks
David
Hayfarmer
11-05-2004 07:33:37
 Re: LIVE PTO Conversion in reply to 18615824, 11-04-2004 20:08:34
I think Mike has the ticket, a parts book is a must on this and is a great thing to have anyway. Do you have a PTO at all on yours? If you sit with the parts book, or prints from a parts CD, you will be able to figure out what you need easily and possibly additional gaskets, bearings etc.
Mike M
11-05-2004 05:30:38
I had a 50 once without live pto,these should be very rare but more than likely not worth as much. I would think that if you had the whole other tractor for parts you should end up with every part needed to change it over. A parts book would be a must to have at hand to check what is needed. You are going to have to go into it pretty far,reduction cover off,trans. gears may have to come all the way out if the bevel gear shafts are differant and in the process you may find some bad bearings and need some seals gaskets and other new parts.If you like tinkering it will keep you busy this winter.
J bouchard
11-05-2004 09:10:23
 Re: LIVE PTO Conversion in reply to Mike M, 11-05-2004 05:30:38
I have done this on a model 50 and model 60. It takes about a day to do this process. Essentially you have to drain all the rockshaft oil, transmission oil and swap the rockshaft and pto assembly from one tractor to the other.
Hayfarmer
11-04-2004 20:21:33
what tractor are you going to put it on?
18615824
11-04-2004 21:07:08
 Re: LIVE PTO Conversion in reply to Hayfarmer, 11-04-2004 20:21:33
It will be put onto a JD50.
BillS
11-05-2004 01:05:32
 Re: LIVE PTO Conversion in reply to 18615824, 11-04-2004 21:07:08
Don't all 50's have live power? Both of mine do.
18615824
11-05-2004 03:53:41
 Re: LIVE PTO Conversion in reply to BillS, 11-05-2004 01:05:32
No they don't. Mine dosen't.
David
buickanddeere
11-05-2004 10:04:46
 Re: LIVE PTO Conversion in reply to 18615824, 11-05-2004 03:53:41
Live pto was optional as was power steering when introcued in April 1954. Hydraulics were always live if equiped with them. Many farmers of that era were raised in the depression and didn't see the need for fancy,wimpy or high priced options.
