wheel weights for H
1951G
11-11-2004 10:59:36
I have bought a 1939 JD H, and have some wheel weights that fit on an unstyled A. Did Deere use these same weights on the H? Trying to keep everything on tractor original or close to factory as possible.
Duane Larson
11-13-2004 20:27:56
 Re: wheel weights for H in reply to 1951G, 11-11-2004 10:59:36
1951G,
Check>Link
for>Link H wheel weight info.
Mike in Louisiana
11-11-2004 18:35:08
1951G, go over to the left side of page and click on help identify then search JD REAR WHEEL WEIGHTS ( see the one by MATT) and see if that helps
Mike
JDVan
11-11-2004 11:07:25
What are the casting numbers on the weights?
1951G
11-11-2004 11:48:58
 Re: wheel weights for H in reply to JDVan, 11-11-2004 11:07:25
JDVan,
I'm not sure right off, I'll look at them tonight, but I do know they are the ones that are correct for the unstyled A with round spokes. I didn't have any "J" hooks to mount them on the spokes.
1951G
11-11-2004 17:42:25
 Re: wheel weights for H in reply to 1951G, 11-11-2004 11:48:58
The casting numbers on the weights are W161 and it has F&H stamped on the other side along with WFF.
JDVan
11-11-2004 18:32:54
 Re: wheel weights for H in reply to 1951G, 11-11-2004 17:42:25
Those are not made by John Deere. They are French and Heckt aftermarket weights and I have not found anyone who has a part number cross reference to application for them. I have seen several 161's and it is my assumption that they fit all Pressed steel wheels on JD's including H's. Whether they fit the spoke wheeled versions or the cast centers is not something I know.
JDVan
11-11-2004 11:07:24
