Torque values for styled G
2510 Bill
11-18-2004 07:53:12
Putting a styled G emgine back together and cant seemed to find the torque values. Iv got an IT manual and if they are in there Im not seeing them. Course I didnt have my glasses on..... I need the connecting rod torques, the head bolt values mainly. Thanks a lot to anybody who responds. Also is there a torque sequence for the head bolts or just the common sense X pattern? Thanks again.
ohiodeere
11-18-2004 17:13:49
 Re: Torque values for styled G in reply to 2510 Bill, 11-18-2004 07:53:12
Looking in my IT book it reads as follows
pg 15 (manual jd4)
tightem connecting rod bolts to 62.5 ft/lbs
pg 11.
tighten stud nuts from center outward and to torque 208 ft/lbs. on all heat treated studs (dark colored) tighten these to 150 ft/lbs
hope this helps
JD G GUY
11-18-2004 10:27:28
not sure of the connecting rod torque setting but i think the torque for the head bolts is 308 foot lbs,
Will P
11-18-2004 14:34:40
 Re: Torque values for styled G in reply to JD G GUY, 11-18-2004 10:27:28
Head is 200 ft lbs. for the hardend studs, if I remember right, not 308.
Will P
ohiodeere
11-18-2004 10:26:54
I just put new rings in mine and got the torque values from my IT manual. look around where they talk about the piston and rings, near the front of the book. i also recall seeing them in the R&R paragraphs.
if you don't have them in your book??? let me know and I can email them to you.
2510 Bill
11-18-2004 18:27:29
 Re: Torque values for styled G in reply to ohiodeere, 11-18-2004 10:26:54
Many thanks to you guys for responding. Ill be back on that project tomorrow and will look again in the IT manual. Got the numbers I need though. Thanks again.
