paint codes
jeremy
02-09-2004 18:47:26
hi i am in the process of restoring an H and i want to use automotive type paint does anyone know of a brand that works good and the code if possible thank you
jeremy
F-I-T
02-09-2004 20:44:50
 Re: paint codes in reply to jeremy, 02-09-2004 18:47:26
Jeremy:
I used acrylic enamel on my '70'D, and the green was PPG DAR code 46180, and the Yellow was Dupont code DT2612.
I have yet to be able to find a good code for PPG in yellow.
Frank
Larry H
02-09-2004 20:03:42
JD used 5 different shades of green and yellow. If you want to be 100% correct you will need to get intouch with Tom Lucht in Omaha Ne. I have done 5 tractors with Centari automovtive paint with hardner and am very satisfied with the out come.
d.siekkinen
02-11-2004 19:29:37
 Re: Re: paint codes in reply to Larry H, 02-09-2004 20:03:42
? for Larry H. I recently used Dupont Centari, but wasn't happy w/ the color. Do you happen to have the code from your paint? Mine looks like an Oliver green or something (way too dark).
