That rubber looks HUGE !
Jim Nauert
11-28-2004 04:08:00
My 420W has spinouts and 13.6 28 rubber on it the rims appear to be original and the tires fit on them nice. I have seen a lot of 420's with the big tires. But did they come from John Deere with them. If not what did they come with.I have a mod. 214 threepoint plow will these tires ride in the furrow ok.I am wanting to use this tractor to plow with come spring.
buickanddeere
11-28-2004 19:40:24
 Re: That rubber looks HUGE ! in reply to Jim Nauert, 11-28-2004 04:08:00
12-28/13.6x28 stock and optional 10-34/11.2x34. Fronts were 5:00-15 and 6:00-16. If using the short rear tires with the tall fronts the tractor will always be driving uphill. They use more fuel that way. My 435 looks much smaller when the 16.9x30 Firestone All Traction Field and Roads are swapped with the 13.6x28 Co-ops.
Henry J
11-28-2004 06:26:57
Jim
That is the correct size for the 420W. That is also the same wheel and tire that just about all the allices WD's had on them.
Hayman
11-28-2004 17:26:12
 Re: That rubber looks HUGE ! in reply to Henry J, 11-28-2004 06:26:57
My 420U has 14.8-28.I like them.
