John Deere 730 Diesel clutch
1rooster
11-30-2004 19:55:50
Before I take the clutch apart, thought I would post what it is doing, to see if I could profit from someone else's experience. The clutch snaps in as it should, however the tractor will not move, until you pull back slightly on the clutch handle, but then it only moves the tractor slowly, and it must be in lower gears to move at all. Any ideas or information, will be greatly appreciated.
Mike M
12-01-2004 19:28:32
 Re: John Deere 730 Diesel clutch in reply to 1rooster, 11-30-2004 19:55:50
Sounds like some facings are missing or installed in the wrong order.
Ken
11-30-2004 21:40:10
Hi,
Try adjusting the clutch a little tighter. Also there are either one or two stop bolts that need to be adjusted. They are located under small covers on the reduction gear cover, one on top and the other on the bottom. You will need to refer to the operators manual to do this properly. ken
