John Deere Loader Parts
John A.
02-10-2004 15:57:43
A question for any JD expert:
I have a 1966 JD 2510 diesel and we separately obtained a loader (designator/JD # unknown)that is lacking the (round) 1 and 1/8" in diameter by approx 4" long pins that connect the loader boom to the loader frame.
These pins are most unusual and have a grease fitting in the center, a recessed area along the circumference at the midpoint of the pin (to allow grease in), and also have an attached 4" bracket extending outward from near the grease fitting to a point at the end of the bracket where a bolt hole is present (this attaches the pin to the frame). In effect, these pins are in an "L" configuration.
Can anyone identify these and would someone like to sell me four of them??
old
02-10-2004 16:57:49
 Re: John Deere Loader Parts in reply to John A., 02-10-2004 15:57:43
There are many companys that use pins like that, cat has them my scout back hoe has them. But any how the last ones I got I had to make, the pins are easy to find just a good old pin then I welded on a plate and drilled the hole and that was that
