2010 fix or trade in
John J. Otto
12-10-2004 10:49:39
i have a '63 2010 with a #36 loader i'm having some hydrulic troubles sometimes not enough power and sometimes no power to the loader but after moving the levers for the 3 pt it will work the tractor also needs tranny work probably all new bearings at least the tractor starts and runs fine but diesel a little after hard work should i have it fixed (don't have time work 3rd shift and run a bussiness in the am)or should i trade it off for something new(er) all the tractor is used for is hauling big round bales ( 3pt) and bush hoging john j. otto
msb
12-10-2004 20:58:09
 Re: 2010 fix or trade in in reply to John J. Otto, 12-10-2004 10:49:39
Have you cleaned the hydraulic filter? That might help it.The cap is located behind the brake pedals and has 3 cap screws that hold it in place,but drain the transmission first.There are two plugs.One is under the front of the drawbar and the other is about even with the brake pedal .Wash th filter in diesel fuel or mineral spirits using a stiff bristle brush.It is a metal filter,not paper. If the filter is damaged ,replace it with a new one.
