John Deere 4320
3020Deere
12-22-2004 11:42:10
I'm looking at buying a particular 4320. It had a dash fire awhile back and every gauge, wiring, etc. was replaced. It was also painted. Overall, the tractor looks very straight at this point. The hour meter reads "1 hour" since it has a new gauge. The fella who has it does not know how many hours are on the tractor. What should I look at prior to buying the tractor to make sure that I'm not getting something that is in need of serious repair in the not too distant future? Any ideas would be appreciated. Thank you in advance.
JD Jack
12-22-2004 16:10:42
 Re: John Deere 4320 in reply to 3020Deere, 12-22-2004 11:42:10
Run it and check for blow by. If possible dyno check it for horsepower to see how tired the enging may be. If eithor the motor or transmission look to be going bad I still wouldn't be too afraid if the price was right because these tractors can be rebuilt to new specs relatively easily.
RickB
12-22-2004 15:45:50
About the first thing I would do is pull the inspection plate from the clutch housing and check for oil leaks; especially from the PTO clutch pistons. Second would be the shifter and whether the internal shift cams are dropping into detent properly. Probably more, but those two are right off the top of my head.
