60 clutch
jody
02-11-2004 19:04:21
when I engage my clutch, it doesn't seem to go into gear all the way. I have to hold the clutch
in to keep the tractor moving.
can someone tell me whats happening?
and how do I fix this problem.
mike
02-11-2004 22:01:20
 Re: 60 clutch in reply to jody, 02-11-2004 19:04:21
sounds like clutch needs adjusted remove belt pully cover there are 3 large nuts with cotter pins in them spaced around the outside edge remove cotterpins and turn these nuts equally a little at a time until the clutch snaps engaged when opperated replace cotter pins and cover and that should fix it good luck mike
