I give up!! 620 Starter overhaul
John VB
01-11-2005 10:38:11
OK, how the heck do you remove the retaining ring-pinion stop assembly from the end of the starter shaft? I think you must compress the ring and remove the stop somehow. I know one way to do it, but I may want to reuse it. Thanks.
Mike M
01-11-2005 11:17:54
 Re: I give up!! 620 Starter overhaul in reply to John VB, 01-11-2005 10:38:11
Take a deep well socket or an open end wrench a push/tap the outer sleeve back towards the drive then you can get at the retaining ring and slide it off the front of the shaft.
John VB
01-11-2005 17:43:36
 Re: I give up!! 620 Starter overhaul in reply to Mike M, 01-11-2005 11:17:54
Well that was simple. Thanks.
Mike M
01-12-2005 08:21:53
 Re: I give up!! 620 Starter overhaul in reply to John VB, 01-11-2005 17:43:36
If you have trouble getting it back together slip a flat washer over the shaft then take 2 pliers and squeeze each side of the retainer and the flat washer and that snap ring should pop back in the retainer.
John VB
01-12-2005 10:37:44
 Re: I give up!! 620 Starter overhaul in reply to Mike M, 01-12-2005 08:21:53
Thanks again. I should be putting it back together sometime tomorrow.
