Unstyled D carb. cleaning
Jer8755
01-12-2005 04:26:25
I am tearing apart a unstyled d carb, and I need to know the best way to get the economizer out of the carb. Right now I am soaking it with Silikroil and still no luck. I know this is a brass unit and it will bend or distort easily if hammered or pryed on. Does any one have a good method of removing this part? Thanks
Dave NE IOWA
01-12-2005 13:03:03
 Re: Unstyled D carb. cleaning in reply to Jer8755, 01-12-2005 04:26:25
Because we do not know of how much experiance you have with blue tip wrenches I would like to add this coment. Brass screws will usually tell you when enough heat has been applied to ---THE SCREW ONLY--as it will flash green. That is generaly enough once it cools down. Dave NE IOWA
Mike M
01-12-2005 08:17:43
On stuck brass heat the screw real hot then let it cool completely,then it should come right out.
