? 49 JD A Pulley end play
joe s
02-13-2004 10:12:13
The pulley has end play when lifted up from 1/4 to 3/8 inch. Wondering if this could be the bearding? No sounds come from the pulley while runing. The motor is quiet. Have not had the JD under a pull of any kind. One opinion I was given was not to do anything for no more than I will use the JD. LOOKING for feed back....
Clooney
02-13-2004 11:18:17
 Re: ? 49 JD A Pulley end play in reply to joe s, 02-13-2004 10:12:13
Joe, pulley end play is actually a side to side movement of the pulley. Your up & down movement is vertical play..
~1/4"-3/8" is a lot but many have been run that way for years.. Your play could easily be bearing wear or inner bushing wear [or both].. You might also have a worn bearing bore in the pulley as that is somewhat common.
~You are lucky on that A, unlike Mike’s B your pulley bearing has an inner race that can be replaced if worn..
~It probably wouldn’t hurt to remove the pulley [mark the clutch driver to crankshaft position before removing so it can be put back the same], then look for wear & re-pack the pulley bearing.. Don’t forget to clean the pulley oil return holes..
~When you get it apart & find what’s loose post back & we can then help you determine how best to repair it..
Clooney
Mike in UP of MI
02-13-2004 10:27:57
If have a model B with the same problem. I took the clutch assembly apart and found that the bearing wore a deep groove in the crankshaft. Besides replacing the crankshaft, is there another way to repair this problem? The groove is so deep that it is affecting the clutch movement. I wonder if this tractor may have done alot of belt work in its life.
Bob
02-13-2004 12:12:17
 Re: Re: ? 49 JD A Pulley end play in reply to Mike in UP of MI, 02-13-2004 10:27:57
When doing belt work, since the clutch is engaged, the clutch pulley turns along with the crankshaft, so there should be little wear on the bearing surface between the two. It is idling for long periods with the clutch disengaged that causes the most wear in this area.
Clooney
02-13-2004 11:39:01
Mike, that's a hard repair.. The problem is you can’t use a press on sleeve as the pulley inner bushing then won't go on over it & you can't turn the splines down to use an undersized bushing or the clutch driver won’t stay tight....
~I did repair a worn crank on a B a few years ago by welding the crank up while still on the tractor then setting up a guide bar parallel to the crankshaft & starting the tractor engine then using that guide bar to guide my grinder to grind the weld back down to original size. It took a while & a lot of stopping to re-mic the crank, it was a pain but actually made a pretty good repair..
JDClooney@aol.com
Mike in UP of MI
02-14-2004 04:22:46
 Re: Re: Re: ? 49 JD A Pulley end play in reply to Clooney , 02-13-2004 11:39:01
Did you use a hand held grinder like a 4 1/2" Makita or something else. It sure would be nice to be able to repair this problem without having to replace the crankshaft. Thanks for the help.
