Jericho, I would suggest you at least drill out the broken bolt that doesn’t have the easy out in it.. Depending on the severity of the tractors expected usage you could probably live with one broken bolt but probably not two broken bolts. If you use a series of smaller to larger drill bits you should be able to keep the drill bit near bolt center & drill it out to the inside thread diameter.. Then SLOWLY & CAREFULLY chase those remaining threads out with a tap.. Seeing as you are asking here it sounds like you haven’t removed many broken bolts.. & those broken below the surface can be a real challenge.. I have removed many bolts like that in my life & what I have found works just great & even fairly fast is to drill the broken bolt with a series or standard drill bits then as I get close to bolt diameter switch to a Left hand drill bit & see if the bit will catch a thread & spin the broken bolt out.. If the drilling doesn’t do it then I use an acetylene torch with a WELDING TIP (not a cutting tip) & heat the bolt center red hot,, then when it’s glowing red I turn the acetylene off & turn the oxygen up & use the flowing oxygen to bubble the red hot slag out.. If doing this on a casting the cold casting will hold it’s threads & allow the bolt to melt right out.. One the side with the broken easy out I would use the torch again but just not drill first.. That hard easy out will melt with a torch flame & blow out with the oxygen easer than a soft bolt.. The torch method is not an easy thing to do for a person not familiar with using a torch or cutting metal so if you aren’t well versed with a torch you might want to find someone that is.. Now on those easy outs.. Those things should be outlawed.. I don’t know why people think that a large diameter rusted tight bolt that twisted off with a large wrench will just come right out with a skinny twisted piece of hard steel that expands the bolt even tighter when twisted in.. Those things only work on a bolt that you could screw out anyhow but just can’t reach.. They at least should properly re-name them to “Broken-Offs”… Clooney
