Injector help
4010 puller
01-22-2005 16:10:33
Hello folks:
I"m wanting to modify some injectors for a JD 4430 engine for pulling. It is an early style 404 with the KDEL (Y-style) injectors and I"m wanting to move up to larger tips. I"d like ot switch to a larger Deere part such as injector tips off of their old V-8 engine. Were any of these injectors the Y-style or does this matter? Are they interchangable from KDEL and KDL?
Thanks!
John
bojoe
01-23-2005 06:15:40
 Re: Injector help in reply to 4010 puller, 01-22-2005 16:10:33
Take your tips out and send them to Tim Engler in Princeton, IN. He can laser the tips out to flow more fuel. Give him a call. He does good work. Here is his website address.
4010 puller
01-23-2005 04:48:14
Fella"s:
I"m running a stock inline A pump maxed out turning 3000 RPM. I talked to my local pump man and he has a set of injector tips (new) for the old John Deere V-8 engines and said they would be plenty big enough if they would fit my bodies but wasnt real sure how that would work. Did the 7520,8630, and others also use 2 types of injectors or not?
Thanks,
John
jr4430
01-23-2005 20:14:16
 Re: Injector help in reply to 4010 puller, 01-23-2005 04:48:14
I have an inline A pump with 10 mm barrels and plungers, up/down cam engine lubed that flows 250-370 cc with fuel chart that has not been on a trsctor since picking up from Scheid Diesel.. Will sell for 1800.00 and ship for free. this would help give some better fueling to the tractor. let me know..
4020dt
01-23-2005 08:16:35
KDL (old style) were used on all 6030 , 7520 and early 404 engines) the 404's up to early 1976 tractors . My 4430 has a real early 1976 serial # 47512 , according to the engine ## they were changed a few thousand after mine . All 84 - 8630's and 466 engines as well as late 404's had the KDEL new style . KDEL(new style) tips will physically fit in the (KDL) old style body but they are positioned 180 degrees off (hald turn) really messes things up , spray pattern is wrong , won't run good , lots of smoke , no power and all that . Pump man told me they would fit , put 8630 tips in , WON'T WORK !!! Ran it only a couple hours so I didn't damage anything . That's when I found the 6030-7520 tips and used them . Original 4430 tip was 4 X 0.33 , 7520 tip is 3 X 0.43 .
KDL and KDEL will not interchange on the head , different holes and threads don't know or sure which is bigger or what . KDEL lines will not hook up to the old KDL pump either . Don't know a thing about the V8 system so can't you there .
4020dt
01-23-2005 04:23:37
There is a tip used on the 7520 or some industrial version of the 531 that will work , that is the biggest one I could come up with a few years back . I wanted to stay with the stock (oem) parts because they were cheaper . KDEL and KDL injectors are not interchanceable nor are their internal parts , tried that . They have different threads in the head , different lines to the pump , and the new style pump has different fitings . With the tips mentioned , 10mm no retard plungers and using the stock lines gives me 325-350hp , and goes down to 165-75 for farming , doesn't start worth a d!!m but didn't start too good when it was new . Any more hp than that will cost more $$$$$ . Remember HP=$$$
jr4430
01-22-2005 21:32:36
how about that inline A pump for the puller?
