Modified Pump for 4010.
4010
01-26-2005 20:17:57
Looking for a good used modified injection pump for a 4010 that will flow more fuel than the stock one. Would like to use in conjunction with a turbo. Any leads or information would be appreciated.
Ryan Brown
01-30-2005 17:14:12
 Re: Modified Pump for 4010. in reply to 4010, 01-26-2005 20:17:57
If you have the later RoosaMaster or Standyne pump you can easily put around 160HP worth of fuel to the engine by turning the plunger travel limit screw inside the pump. The other extreme is to take a 404 from a 4430 and use the Bosch inline style pump, then you can basically pour fuel to it until pistons crawl out of the block.
