What oils are best for Dohn Deere 310E?
Jim310E
01-29-2005 21:06:12
I have a 1999 JD 310E backhoe being delivered next week. I plan on changing all the fluids when it arrives. I want the best oils for it but would like to save money if possible. What is the best engine oil? Is the synthetic trans and HYD oil better than regular oil? I was shocked to see what Amisol trans oil costs. Any information you could privide would be really appreciated. This is our first tractor and I want to give it a good home....Thanks again!
buickanddeere
01-31-2005 06:28:27
 Re: What oils are best for Dohn Deere 310E? in reply to Jim310E, 01-29-2005 21:06:12
The synthetic trans/hydraulic is only needed in extreme cold or extreme heat conditions. Synthetic in the engine & grease gun is cheap enough. Changing the coolant to propylene glycol mixed with distilled, not tap water maybe a consideration. Not poisonous to pets and children if spilled. And if some should ever leak into the engine it's far less damaging.
ktdiesel
01-30-2005 13:18:31
ktdiesel
01-30-2005 11:56:23
