Mag tester question for Duane
34gpa
02-07-2005 14:01:15
I just picked up another John Deere mag test stand and this one not only had the cast forged L bracket for the base mount mags, but also a channel bracket about 5 inches long with 2 square holes and a slot in the middle between them. The holes line up with the bolt holes on the test stand. What in the world is it for? It has a part no. on it, same type as the L bracket. Thanks
430WLPG
02-08-2005 17:44:09
 Re: Mag tester question for Duane in reply to 34gpa, 02-07-2005 14:01:15
Could you post a pic of the L bracket ,as I have a tester and I wondered how to run a base mount,I don't know what kind mine is
Duane Larson
02-07-2005 20:56:24
34gpa,
Well, you got me. Is it a cast piece - if not, how is the number put on the piece? Is it possible it is a modified base-mount bracket? The parts list for the Deere magneto tester does not show anything like that. Neither does DIR 306, the Deere magneto repair manual that shows how to operate the tester. And, I am (at present) at a loss to figure out what it would be used for. Unless it was to hold a magneto with a gear drive, like on the LA or some such, but that would take other changes in the tester. Is it possible to post a pix of the piece, or email one to me?
34gpa
02-08-2005 12:15:13
 Re: Mag tester question for Duane in reply to Duane Larson, 02-07-2005 20:56:24
I will try to post a picture tonight if I figure out how to do it. But yes, it is cast and has a no. on it. I will get that also.Is that Dir 306 the correct no. for the instructions?If so I'm going to order one. Thanks
Glen in TX
02-09-2005 14:13:41
 Re: Mag tester question for Duane in reply to 34gpa, 02-08-2005 12:15:13
I have some other info and brochures on the Allen test stands. Adapters for other types of mags, aircraft mags, generators, and starters were available for them. If you post a pic of it let me know.
