'50 Model B oil
Jeffro1
02-11-2005 08:42:52
I am wondering about the oil I am using in the model B. I don't run in cold weather, but I do need to change the oil soon. Are these things really picky? I probably should stick with the JD stuff, but man it is expensive. What works best for these things?
-Thanks
Jim Nauert
02-11-2005 17:17:02
 Re: '50 Model B oil in reply to Jeffro1, 02-11-2005 08:42:52
I use sae30 in my 51B. You can use SAE30, 10W30, 15W40. If you are using it only in warm weather use the SAE30. Just buy a good brand it doesn't have to be john deere. The oil bath uses SAE30 as does the hyd. and first reduction gear.
mattd
02-11-2005 14:47:06
if you dont run it in cold weather then you should be fine with 10w-30 or a straight 30 weight. or you could go with a heavier oil if it burns a little. just use the same brand you use in your vehicles. these old tractors dont care how fancy the oil is.
matt
