1953 JD 50 wiring diagram
Daniel Hartzfel
02-12-2005 13:32:27
I recently stripped all the wiring out of my JD50 for restoration. Does anyone know ehere I can find a wiring diagram for one?
John Van Valkenburgh
02-12-2005 20:47:34
 Re: 1953 JD 50 wiring diagram in reply to Daniel Hartzfeld, 02-12-2005 13:32:27
third party image
Daniel,
This is the wiring diagram for the 50 that John Deere supplies.
I rewired my own 50 or as a previous poster suggested you can buy a complete harness. If you do make your own I'd suggest that you pay particular attention to clean tight ground connections, and solder all terminals. The terminals have to be able to take considerable vibration and weather. I used heat shrink tubing to insulate the terminals. I also used lots of wire ties to keep things from flopping around.
I'm including a link to the generator details.
Best of luck,
John
1953 Model 50
Duane Larson
02-12-2005 17:39:25
Daniel,
You might consider getting a new wiring harness from www.wiringharnesses.com they have new ones built for the 50, and work great.
ChuckW
02-12-2005 17:31:02
that would be available in the parts manual.
