German 820 John Deere Brakes (1972)
John Mackey
02-21-2005 12:38:02
The right brake is sticking. I'm not sure how these brakes work. They are inside the rear axle. It must be removed to get to the actuating disk, disk, etc. I appreciate any information that might help me in this repair.
Thanks,
John
cannonball
02-22-2005 06:10:01
 Re: German 820 John Deere Brakes (1972) in reply to John Mackey, 02-21-2005 12:38:02
is your right brake petal coming back up..might be sticking to pin in brake petal....have nice day may god bless
jdemaris
02-21-2005 20:28:38
820 German built Deere is basically the same tractor as the AG 1020 or Industrial 300. Wet power brakes in the planetary final drives. They will grab and/or stick if the oil you're using does not have the proper wet-clutch/brake additives. Kind of the opposite problem you get when you use oil that HAS the additives in a machine like a Cletrac crawler - and then the brakes will NOT grab enough. Your sticking could also be due to a brake valve malfunction also - but it's rare. They work so well, that even when the linings are completely torn - or - worn off, the brakes still work okay. Shows up in the hydraulic intake strainer. I've pulled apart a few that were sticking or a little noisy only to find just about nothing left inside but metal filings.
buickanddeere
02-21-2005 17:25:12
Disconnect the brake line as see if it still sticks. Did anyone by chance dump some gear oil into the transmission?
JMackey
02-22-2005 12:55:46
 Re: German 820 John Deere Brakes (1972) in reply to buickanddeere, 02-21-2005 17:25:12
Last summer the right brake would not work at all. It went to the floor and would stay their until I pushed the left brake pedal.
I cleaned the intake screen, relpaced the transmission oil filter, and replaced the hydraulic oil with a John Deere"s product. I bleed the brakes and new clean oil came through the line. I think the old oil had water in it. The old oil was the color of penut butter. The tractor had been used very little for the last 6 years. Now the right brake drags all the time and when the right pedal is pushed it will only move about 1/2 inch.
Thanks,
John
buickanddeere
02-22-2005 15:31:46
 Re: German 820 John Deere Brakes (1972) in reply to JMackey, 02-22-2005 12:55:46
Uh oh. Both right and left brakes have to come apart.
