JD A carb
jgoug
02-25-2005 07:27:35
I have a 1940 model A all fuel. This tractor will always run only on gas. I need a carb and need to know what carbs will work and which will work best for this model before I start looking.
Larry806
02-25-2005 09:47:33
 Re: JD A carb in reply to jgoug, 02-25-2005 07:27:35
Your tractor should have came with a DLTX 24
It shoild run fine with a DLTX 33, or the more common DLTX53. The 24 was used on the unstyled G tractor and you'll find them to cost more most of the time I have several 33's & 53's if you don't find any
