Here is a story that I sent to a JD buddy just after I bought this 435D: I have this neighbor down the road from me - had this tractor sitting way back off the road - never moved. Been driving by it for years wondering what it was. I could see green so I thought maybe an Oliver. I"m currently tinkering on my 59 Oliver 770 so one day I stop by the house (nobody home) and left a note asking if it was for sale. Turned out the tractor was a JD 435D. Yeah, the 2 cylinder GM with the blower. Cool! But, seeing this I figured it was not for sale and never would be. But I left the note anyway. Didn"t hear anything until Yesterday (28FEB05). Owner called me and was willing to sell. I still didn"t know much about the tractor - just that it was made for 1 year and fairly rare. Thought it was strange that the guy calls me exactly 2 hours after finding out grandpa had passed away (My grandfather had a large JD collection). Thought maybe it was a sign from above..... . So I met the guy at his house yesterday morning to discuss and get a closer look. Here"s the story: Guy bought it around 1990. Traded an 801 Ford plus cash for it. Used it for maybe 8-10 years to pull a 5" brush hog. Said a collector had been around and told him he was an idiot for using it, that he needed to slap on some new paint and set it up on a trailer and let it sit. Collector had been trying to buy it for years but no sale. I believe a neighbor borrowed it and broke the pinion/ring gear (neighbor apparently is real good about borrowing and bringing back broke stuff). Found a broke trans gear too so the guy bought all new gears, shafts and rear end gears (over $1500 worth). Got the tractor assembled except for the 3 point and some sheet metal. He then got very sick, nearly died in the hospital and never touched the tractor again. So back to yesterday. He claimed he had the engine running last year and that it was in great shape. There was no fuel (pulled the drain in the filter - dry) but it did crank over and sounded ok. Said all I needed was new battery, fuel, and fill the trans with oil and should be ok. Son-in-law had the generator, regulator and other electrical items replaced last year too. Sounded good. All 4 tires were up and not in bad shape, sheet metal all there and pretty straight, paint faded but everything still readable, home-made battery box (junk) and the front axle has some major (cast) welding where I"m sure somebody jerked a bit too hard with a tow chain and broke it. He was asking $2500 and since I didn"t hear it run I offered $2250. He took it. So now I am the new proud owner of my first JD and thought I had nailed a jackpot (knew grandpa would be proud)..... ..... ...until I tried loading it on the trailer. Rear wheels are locked up..... shifter is in neutral, clutch pushed in, brake pedals disengaged....crap...this is not good..... ...Shifter seemed strange, couldn"t engage 2 of the gears but the rest were ok (so I thought). Decided to pull the top shifter plate and see what was going on. Now, crap turned to the "S" word. Since there was never any oil in the trans..... EVERYTHING has a nice coating of RUST. On top of that, my guess is when he reinstalled the shifter assembly with the forks - he missed ALL THREE sliders..... ...grand kids come over to play on tractor shifting gears..... everything is all out of whack now - then froze up. Two gears are lined up over a single drive gear and another is not in its neutral position either. So, its locked in 3 gears at the same time and because of the rust..... .....I"ve soaked the whole works in penetrating oil hoping it will break free but I don"t think it will. The rust seems to be coming off the shafts and gears but I"m hoping everything could be bead blasted and re-used with minimal pitting. Probably will have to buy all new bearings at a minimum is my guess. I will add new posts for updates on this latest "project".
