Will wheels work?
Jim 52G
03-11-2005 08:40:45
I was looking at late 40"s or 50 something Massy Harris tractor mostly together with 13.6-38 tires the same as my JD-G. It had the steel wheel like you see on some johnnys with 9 bolt pattern and aprox 7" middle hole diameter. i didn"t have a way to measure for sure just used my hand. Does anyone know if these wheel are interchangable with john deere?thanks
Duane Larson
03-11-2005 20:47:44
 Re: Will wheels work? in reply to Jim 52G, 03-11-2005 08:40:45
Jim 52G,
As noted earlier, they will bolt up. However, JD wheel centers touch the rim at four places, where they are either riveted or welded. Other wheels (Massey, MM, Oliver) normally touch the rim at five places, so you might check this if it matters to you.
JDBert
03-11-2005 08:54:37
The wheels would work on a "A" or "B" with pressed steel hubs. But for your G they wont work you have to stay with the cast or get adapters made to convert to the pressed steel 9 bolt pattern. You could dismount the tires and mount them on your "G" rims though.
