Temp gauge will not work
jlow
03-14-2005 12:12:52
The temperature gauge on my model 70 will not work. How is the best way to go about trying to figure out what is wrong with it. Start at the sender or the gauge.
F-I-T
03-14-2005 12:22:41
 Re: Temp gauge will not work in reply to jlow, 03-14-2005 12:12:52
Well, there is no sender per se. There is an ether filled bulb which hooks to the gauge unit by means of a capillary tube. Best mtest is to remove the bulb end from the water pipe, and place it in some boiling water. If it doesn't register, then there is probably a leak and the ether has evaporated. Some can be repaired, but it's usually much more efficient to buy anew gauge.
Frank
JD @ Antique Acres
03-14-2005 12:14:17
I would start with the sender.
Magoo
03-15-2005 13:15:30
 Re: Temp gauge will not work in reply to JD @ Antique Acres, 03-14-2005 12:14:17
Make sure the engine is warming up, cover part of the radiator for a while to see if guage will move. Someone may have removed the T-stat and it is running cold.
Magoo
