510 Backhoe?
1 Bob
03-15-2005 17:15:15
My neighbor has a 1977 or 1978 JD 510 backhoe and lately the transmission has been acting up.It will move if it is on level ground but it will not go up any slight incline the machine stops and acts like the clutch is slipping? Also if you go down the road and try to shift into seventh or eighth gear it acts like the clutch is slipping. So he had it parked until he got around to replacing the clutch but today when he needed to use it he could not get the backhoe or loader to move. He never had a problem with either of these before. Could the clutch be causing this to? Any other things we could check? Thanks Bob
