50 20 with 7520 engine
jimvw
03-16-2005 17:25:41
Junking out a 7520 and putting the engine in my 5020. Do I dare use the clutch cover from the 7520? It apparently has stronger springs in it. The 7520 had a hydraulic booster to help operate the clutch. Will I be able to operate the clutch pedal on the 5020 If I use the 7520 clutch? Maybe someone has done this? Thanks
G/MAN
03-17-2005 07:49:53
 Re: 50 20 with 7520 engine in reply to jimvw, 03-16-2005 17:25:41
The same clutch cover was used in the 5020, 6030 and 7520. It appears that different disks were used behind the 6531A (aftercooled, i.e. 6030/7520) engines than the 6531D (naturally-aspirated, i.e. 5020) though, so I'd use the disks out of the 7520 if they're reusable or install new ones of that part number. I'd also REPLACE the inner and outer springs with the 6030/7520 versions. Also inspect and replace the fingers and other hardware as required.
