1010 information about oils
jlc50
03-25-2005 08:02:46
I need some information on a 1010. What kind of oil is used in the rear end and transmission and also in the hydrolic systems?How much of each is used. Also it has four plugs about 3/4 inch in the rear of the tractor are these to check the fluid in the rear end? Thanks for any help This is not my tractor and I do not have any boks to help me with it. Thanks Johnny.
buickanddeere
03-25-2005 16:47:39
 Re: 1010 information about oils in reply to jlc50, 03-25-2005 08:02:46
Trans GL-1 or GL-4 Marine 90 or 140 weight. Depending on the chassis style the final drives are separate from the trans but use trans lube. Serial number below 31,000, between 31,000 and 42,000 or over 42,000? Hydraulics.....Hyguard.
Loren NC
03-25-2005 10:47:16
I can get the information for you if someone else doesn't provide it. I don't have my book with me now so it may be later in the weekend.
jlc50
03-25-2005 15:49:55
 Re: 1010 information about oils in reply to Loren NC, 03-25-2005 10:47:16
Loren
Thanks for the reply. If no one else replies I will be looking for your information. Thanks
