head casting numbers two cyl JD ?????
Jerry Hull
02-19-2004 16:20:16
I have two heads off of two cyl J.D. Was wondering if anyone can identify them by the #'s The first one is F3211R I think it might be a 720 or a 730. The next head is A3367R. I also found a three cyl. diesel head with casting #R5868. Any help identifying them would be great. Thanks Jerry
Ralph
02-20-2004 20:46:29
 Re: head casting numbers two cyl JD ????? in reply to Jerry Hull, 02-19-2004 16:20:16
Jerry
I crawled under all three today. Couldn't find a number, but tonight it dawned on me the casting # is on the front inside the tappit cover. But the two-fuel head is about 5 1/2" thick while the higher gas head is 5 1/4" thick. I imagine push rods differ by the same length.
RK
02-20-2004 13:55:55
the F3211R fits 720 -730 Diesel. Roger
Ralph
02-19-2004 17:58:03
Are these going to be for sale? I may be interested in a head for an A in the near future.
Anderson
02-19-2004 16:44:48
I am pretty sure that the A3367R is for a John Deere 60.
Ralph
02-19-2004 17:54:25
 Re: Re: head casting numbers two cyl JD ????? in reply to Anderson, 02-19-2004 16:44:48
Parts book lists it as a head for 47- A also. Not sure if it is the gas or two fuel head. It is not listed as a head for the styled AR or the earlier A. I have access to a 46 A, a 50 A and a 50 AR if you want me to check the casting numbers on each.
Jerry Hull
02-19-2004 21:31:08
 Re: Re: Re: head casting numbers two cyl JD ????? in reply to Ralph, 02-19-2004 17:54:25
If you would check the numbers that would be great. Is there something I could look at on this head to tell if it is duel fuel. The last two cyl I owned was a hand crank H. And I was only 14, wow 36 years ago. These heads are some that my brother has had for about six years, they have been checked out and he said they were perfect. If anybody is interested I am sure he would sell them, I would just have to see how much he would want for them.
