what tires for JD 40 std
Jim Wait
04-05-2005 08:20:16
Ready to purchase new 16" tires----what do I ask for?
Thanks
buickanddeere
04-05-2005 09:47:52
 Re: what tires for JD 40 std in reply to Jim Wait, 04-05-2005 08:20:16
HD tubeless such as Titan, then put some wonder glop inside to seal the leaks. 6:00-16 ride a bit high on the front compared to 5:00-15's
Bill_40S
04-05-2005 09:36:45
600x16 3 rib front tractor tires, 4 ply unless you have a loader. Should be about $50 for Firestones.
Jim Wait
04-05-2005 11:08:12
 Re: what tires for JD 40 std in reply to Bill_40S, 04-05-2005 09:36:45
Do I need to load the tires as I don't intend to work this tractor again?
DiggerLarry
04-07-2005 20:07:00
 Re: what tires for JD 40 std in reply to Jim Wait, 04-05-2005 11:08:12
I would not put anything in them, even Fix-a-Flat or any other sealer. That stuff really messes up a rim. If you have bad rims, use a tube. If you're not using heavy implements on the rear, no need for the weight of water fill.
