4010D Snow Plow
Jim in AK
04-09-2005 22:44:56
I got an eight ft. dozer blade on it now. I would like to have a SNOW plow for the snow the dozer blade works but I think I could do better with a snow blade. Was thinking of building one. Any of you got any suggestions.
I Bleed Green
04-10-2005 05:41:49
 Re: 4010D Snow Plow in reply to Jim in AK, 04-09-2005 22:44:56
Take a look at the snowplow blade i made for my 4020.
Jim in AK
04-10-2005 09:24:46
 Re: 4010D Snow Plow in reply to I Bleed Green, 04-10-2005 05:41:49
Thanks Bleed, That looks great. Would you be so kind as to share your plans for that plow? I'm pretty good with a torch and welder myself. I also got several hyd. cylinders that would work well for that job. If you don't have plans a couple of up close photo showing more detail would be of a great help. I built a Hyd. wench for the 4010 but have not tried it yet because of a selective control valve problem that I just replaced, last month. I built a boom for the front for putting saw timber on the A.P.B. saw mill. APB= Alaska Poor Boy.
Jim in AK
I Bleed Green
04-10-2005 09:47:29
 Re: 4010D Snow Plow in reply to Jim in AK, 04-10-2005 09:24:46
I can take more picturs of it, but it will take a few weeks. I didnt have any plans, i just made as i went and use steel i had from old machinery. The company rolled the blade and the ribs the way they roll many others they make. I would have to look it up, but i know having them roll the blade, make the ribs and the steel was less then $200, but that was before steel went ski high.
Jim in AK
04-10-2005 11:31:42
 Re: 4010D Snow Plow in reply to I Bleed Green, 04-10-2005 09:47:29
Bleed, Did you get my email reply?
Jim
I Bleed Green
04-10-2005 14:30:43
 Re: 4010D Snow Plow in reply to Jim in AK, 04-10-2005 11:31:42
Yes i did
