70 flywheel
2 popper
04-11-2005 06:05:17
I need the weight of a 70 flywheel with the starter ring still on it.
Thanks.
old joe in Michigan
04-11-2005 17:02:04
 Re: 70 flywheel in reply to 2 popper, 04-11-2005 06:05:17
HI 2 popper,
I just happened to have my JD 70 gas fly wheel still off as I am rebuilding the engine, so I went out to barn and weighed it for you.
It is a taper lock # F1226R made by Allen foundry works. It weighs 153lbs including the taper lock nut and collet and it has the starter ring gear on it.
Hope this helps
old joe Michigan
Blksmok
04-11-2005 08:35:37
2 Popper....about 210#.
Dan in Ohio
04-11-2005 06:38:51
2 popper,
I don't know what they weigh but I always use my portable shop crane when have to remove them from the tractor. I've had the flywheel off both of my 70's several times using the crane. Its save and quick. That shop crane has save my back more times than I can remember.
