M hydraulics
Jim
02-21-2004 18:11:17
Where do you check and add the oil on the M hydraulic system?
Matt R.
02-21-2004 21:28:23
 Re: M hydraulics in reply to Jim, 02-21-2004 18:11:17
Hi Jim:
There is an oil level test cock underneath the seat, (above the belt pully gearbox if you have one). This is also where the hydraulic drain plug is located. The oil is filled by removing the breather cap near the Touch-o-matic lever and pouring in oil until it runs out the test cock. The operator's manual says this system takes 3.5 quarts of SAE 10W.
Hope this helps.
Matt
Bill
02-22-2004 04:47:25
 Re: Re: M hydraulics in reply to Matt R., 02-21-2004 21:28:23
I have a complete 3 point hitch conversion to fit the M if your are interested.
