Good Evening John, I will try to answer your specific questions, plus also explain what the switch is doing and why which may help you figure it out. 1) Why a lead to the Generator? Thats so the gauge has power and works when the tractor is turning (button NOT pushed) the generator, its the Generators output thats powerign the gauge when the tractors running. 2) How to hook up??? See below. 3) See Below?? 4) What happens is that when you push the button, the fuel gauge receives its needed power and works off the Battery, NOT the generator then, that way you can check the fuel when the tractors NOT running. **************HOW IT WORKS AND WHY************** 1) The gauge needs power, either from the battery (switch pushed) when the tractors not running,,,,, ,, or from the Generator (switch NOT pushed) when it is. That way, the gauge isnt drawing current and runnign the battery down when the tractors NOT running. But, its stil possible to check the fuel level not running by depressing the switch. 2) That switch is a Single Pole, Double Throw, Momentary spring return type of switch. The 2 Throws are like the 2 contacts, one is Normally Closed (To Gen) and the other is Normally Open (To Battery) UNLESS AND ONLY WHEN the switch is depressed, in which case the gauge is then powered via the battery instead of the Generator. 3) The single POLE is the common switch terminal to teh Gauge and the 2 Throws lead to the Generator (Normally Closed) and the Battery (Normally Open) 4) Take a battery powered light up type continuity tester or an ohm meter and the commom Throw terminal is the one thats in contact with the "to Gen" terminal when switch is NOT depressed, but opens there and makes conatct with the "to BAT" terminal when it is. Post back or e mail me at jmn50@msn.com or call me at 812-824-4608 any questions. Good Luck, God Bless, Sure hope this helps yu understand how it works. John T Nordhoff
