trany noises
John K
05-14-2005 19:02:28
I own a 1978 3130 JD. I began hearing these strange noises {pinging} from the trany-differential area.My tractor has a 6 speed transmisson with hi-low {rabbit-turtle} shift.Is my hi-low shift starting to go? I did hook onto a large tree root while plowing a fence line.I came to a dead stop and then I heard grinding noises from the trany. Could this have caused some damage? Has any one else had this problem?
buickanddeere
05-15-2005 13:32:32
 Re: trany noises in reply to John K, 05-14-2005 19:02:28
Which serial number range of the 3130? The late 3130's were much beefed up in the trans to 3140 specs. The early 3130's can be trashed with a few rough moves. The parts section of the Deere web page shows what was updated.
txgrn
05-15-2005 06:21:56
No doubt that bringing the tractor to a full stop while hooked up is definitely hard on gears. You may have broken a tooth off a gear.
I mean if it didn't and now it does..... .sounds like gloom and doom for you too.
Mark
