JD G Pan Seat Fan Blades
40 JD G
05-15-2005 20:17:57
I am restoring my 1940 G, and it has a 3 hole seat, is this the right seat, some other ones i saw had the 5 hole seat. Also does any body know if the fan was still painted yellow on the 40 G"s. Thanks.
Glen in TX
05-16-2005 13:31:43
 Re: JD G Pan Seat Fan Blades in reply to 40 JD G, 05-15-2005 20:17:57
You can do some paint removal in layers on the fan and find green under the yellow and do what you want on that. Most of them were painted yellow later. Some very early Ds had the fans painted white over the green. The 3 hole large pan seat would be fine if you can't find a 5 hole and there was even a 9 hole used.
Pat Browning
05-16-2005 07:18:20
I cannot help you much on the seat, but so far as the fan blades are concerned, it was the JD servicemen who applied paint to the fan blades -- started back with Model "D" tractors so I am told, and the reason was a safety feature so one could see the fan better & thus not extend their hands into a turning fan! Given all this, I maintain that it is a personal thing -- my fan blades are not painted -- they collect lots of grime and do not remain a neat yellow for very long anyhow! (PatB)
