1983 JD 410B troubles
joey327
05-16-2005 15:02:02
hello:
I have a 1983 JD 410b backho that starts and runs fine, but after awile it looses power and wants to die out. If I wait about 10 secs and then start it again it runs fine for about 2 mins and then looses power. Anyone have any suggestions. I checked all fluids and topped up but no help. Fuel? Fuel pump? Injector pump? Any help is appreciated.
jdhbag
05-16-2005 16:12:41
 Re: 1983 JD 410B troubles in reply to joey327, 05-16-2005 15:02:02
I had the same problem with mt 410B. There is a low pressure return pipe that comes out the top of the injector fuel pump going back to the tank, at least it is on mine. This returns fuel to the tank and in the fitting that comes out of the pump has a ball check valve in it, which is tiny. That may be stuck. This caused my 410 B to do the same thing as yours is doing. The mechanic removed that little ball and it worked great until i could get another valve to replace the old one. Good luck
cannonball
05-17-2005 04:45:43
 Re: 1983 JD 410B troubles in reply to jdhbag, 05-16-2005 16:12:41
yes and if that check is stopped up and stops up again most likely you will have a problem with injection pump..a plastic ring starts coming a part...you will have to have pump fixed ..have nice day may god bless
