JD500 (industrial 3020) diesel throttle irregular
Jim Presley
06-09-2005 21:17:44
I recently got a JD500 going that had been sitting for about 5 years. Generaly runs good, but the throttle is REALLY touchy. Move the throttle lever just to the right of center and it just takes off. At times when it is running as one would expect, the throttle just takes off, and hits a point in high RPM where it sounds like you turned it off, but it recovers just before you think it will die at low idle. At any time you are driving or working the hydraulics it just seems to go all over the place as far as engine speed. Intake air leak? It is a diesel, 270.
Thanks!
Jim P
Tx Jim
06-10-2005 03:16:21
 Inj. pump governor bad in reply to Jim Presley, 06-09-2005 21:17:44
Jim,probably the inj. pump needs attention.Tx Jim
